Bongolation is correct. I would also recommend the B-2R. It is a fine sounding little amp and is indeed the very same amp that is built into the SVT 350-H. They just mount it into a big wooden box to make it LOOK like an old SVT head. And they charge you quite a bit of money for that big wooden box. You are better off getting the B-2R and taking the money that you save to buy a nice rack. Get one with some extra rack spaces so that if you buy a tuner, or a voltage regulator, or a wireless unit, or whatever, you'll be able to mount that in the same rack.
As for the reason that one amp will often sound louder than another amp that is rated at a much higher wattage, well, this is a very simple question to ask, but a very difficult one to answer.
First of all, let's talk about how amplifiers are rated. A certain wattage rating will simply mean that a certain amp will produce a certain amount of watts before it hits a certain distortion rating. The spec might be .5% harmonic distortion, for example. Well, a transistor amp won't distort until you push it REALLY hard, and then it will start to break up in a sonically unpleasant way. A tube amp starts to produce distortion at very low levels. However, because the harmonic distortion that is caused by tubes is such a pleasant sound, you can continue to turn it up WAY past the initial onset of distortion, and still get nice tones. That 150 watt transistor amp that you mentioned might not hit .5% harmonic distortion until you get to about 8 or 9 on the volume knob. Up until that point, it just gets louder, not significantly more distorted. Your 60 watt tube amp might hit .5% harmonic distortion at about 2 or 3 on the volume knob but, as I'm sure you noticed, it continues to sound great WAY past that point. A tube guitar amp, even when distorting at ten times the specified harmonic distortion level, will still sound very nice.
Then there is the whole issue of speaker sensitivity. All other things being equal, 60 watts of ANY kind of amplification through a speaker that is rated at 91db efficiency will sound about the same as 120 watts of the same amplification through a speaker with an efficiency rating of only 88db. I've oversimplified some of these concepts a bit, but you get the general idea. What it comes down to is that, based solely on the power rating of an amplifier, you can't really tell how loud it is going to sound, at least not until you have some more information.
Hope this helps.
Brad
