a limiter is basicly a compressor with a very high ratio. you usually cant adjust the attack and release, and since the ratio is set, it is mostly used to stop transients from clipping your recorder. generally it should be hardly working, but i guess if you wanted it for an effect you could squeeze the life out of something
