D
Ding Dong
I have a TSR-8 that is starting to show its age. Grooves have formed on some of the transports and/or the lifter mechanism. This is causing brand new tape to shed, gunking up the heads.
Ive had my problems with sticky shed in the past, and now i'm using only brand new SM900 tape. (i'm only using the 900 because 911 was unavailible when i bought it- I'll be switching to 911 soon)
I want to replace the worn out parts if possible. I'll have to check the schematic to see if it's something i'm capable of doing, then see if tascam has the part. If everything goes well, I'll be very happy...
Then I'm still left with the question of the heads and how much damage they have sustained from all of this. Does excessive cleaning and tape shed cause heads to wear faster? I'm assuming it does, therefore i am considering having the play/record head re-lapped for $90.
The problem is that i don't even know what re-lap means... The heads still sound good to me, they just gunk up pretty fast. If someone could explain what re-lapping is i'd be very grateful. I was told that if the rec/play head doesn't feel smooth to the touch, it needs a re-lap. Mine doesn't feel smooth to the touch...
any advice? thanks in advance for all the great info i get here....
Mike
Mike
