I've not seen such a booth, I just took some typical dimensions and ran them through a handy little freebie demo of a $1000 program for figuring STC and TL of walls, ceilings and windows - you can get your own free copy here -
The demo is crippled (duh, free vs $1000) but it's still pretty handy. For example, even though the wall calc only lets you use 1/2" gypsum, it lets you use up to 20 layers per side; and, if you click on Material Constants you CAN change the Density - 1/2" sheet rock is 690 kg/m^3, but (on a per session basis) you can change that to whatever you want. If you change it to about 1800, then each 1/2" of "gypsum" is really 1/2" of CONCRETE.
I've used that to model what the STC and low freq TL is for 8" concrete walls with 8" air space and one 1/2" gypsum (just don't change the Density for the second side) - I'm planning a new facility in a couple years, need the isolation but don't want bass traps EVERYWHERE inside, so the lighter inner panel will act as panel type bass traps and still keep isolation good (concrete and air does most of it)
Anyway, sorry I don't have an actual all-glass booth to talk about, hope you enjoy the "freebie"... Steve
