Kevin Blight
Does anybody know of any way to upgrade my Alesis? I'm wondering if there is a replacement chipset or any way to get other sounds onboard. I don't want to go the high tech route and use it to trigger samples etc.
Also, as it only has 4 outputs what have other people found the best configuration to use? I usually put bass drum and snare out of output 2 (panned >3 and <3 for separation) put the toms and percussion out through 1 in a stereo spread and stick the hi-hats through with the snare as a little reverb doesn't hurt and as long as the balance is OK that seems to work pretty well.
If push comes to shove I would consider replacing it, so any advice concerning a good replacement that is as easy to use would be welcome. Price range of say £200
Kev
Kev
