AES/EBU Cables for Mics
Modus
Zaireeka!
I picked up what I thought were normal XLR male to female cables but I when I got home and looked a little closer I saw that they were AES/EBU 110 ohm cables. I did a search but I couldn't figure out if these are OK to use with condenser mics as a mic cable.
I don't want to blow up my mics!
yeah they will work, actually better than regular XLR's
you thought u was gonna blow up if you plugged em in, actually pending ya pre-amp it would make ya vocals clearer or should make it clearer pending on ya ohms capacity...
Every single interconnect in the main chain here -- Digital *and* analog -- are Belden 1800F AES/EBU cable.
Farview should know... :D
In any case, you're fine. You might not be the other way around though...
