deepseasquid
Hey all...I'm setting up my DAW, and have the first drive partitioned as (C): OS-XP Pro, at 10 GB. The other partition on the same drive is (D): 30 GB. Now, I have some other drives that I will/can use for audio data/samples/backups. Since I haven't set it up this way before, my question: For audio applications (Sonar, Sound Forge, etc.), is there any advantage of installing them in the (C) partition, or is it just fine to install on the other partition(D), which has more room? If it doesn't matter, I would probably install those apps on the (D) partition, so I wouldn't crowd the (C) partition. Sorry, I know about the system drive and audio drive being separate, but I have been unable to find anything about installing apps to other partitions other than the main OS drive, and the consequences(or drawbacks) of doing so. Thanks in advance. My computer before this had a 40 GB non-partitioned drive for OS and apps, so this was not an issue.
