It's possible to do it, but probably not a good idea. If there's no external speaker jacks on the amp, then the amp prolly is designed for the exact impedance of what the speakers are wired to. Be VERY careful adding speakers, if you make the overall impedance lower you could damage your amp.
If you're gonna wire more speakers, you have to do it in series, or some combination of series/parallel, you can NOT lower the overall impedance that the amp sees! This can NOT be stressed enough! If you wire speakers in parallel, which is how typical cabs are wired, you'll draw more power from the amp at the risk of frying it. You could easily be sucking 200w+ out of that amp if you do it wrong.
The problem with series is the overall impedance will go up, causing total watts delivered to go down.. Totally safe for the amp, but it'll push less total power into even more speakers. You currently have 140w into 2 speakers (70w ea), add a couple speakers, then be pushing 100w into 4 speakers (25w ea). Now you may not be pushing the speakers hard enough to get the sound you're expecting b/c speakers have different sound qualities when they get to the limits of their excursion. The best you could do is to get all 140w into all 4 speakers evenly, which would be 35w/speaker, half the rated power..
Also - If the speakers aren't all the same impedance, some will get more power than the others, so you gotta watch that too...
