my machines LED screen is somewhat off center, not so you cant read it, but its just noticable. i was just wondering if this will be a problem, or if its just a little annoyance to deal with.
Machine must've slipped past QA... it's not a problem unless you can't see some of the LEDs or if it bothers you cosmetically.
Functionally for the machine, it won't matter.....
Depending on whether the machine's on warranty or not, and your technical ability, you might open it up and see if the LED screen simply needs re-seating in it's housing. If it's under warranty, then get Alesis to fix it.
