Acoustic question
  • Thread starter Thread starter grinder
G
grinder
I have a Seagull S6, spruce top and am wondering if it would be worth replacing the Tusq nut, saddle and bridge pins with bone? Would this help with the sustain and clarity?
Thanks, Grinder
Thanks, Grinder
How well does the saddle fit? If it falls out easily when the strings are off, then yes a well-fit bone saddle will improve the volume and tone. If the nut is badly slotted I'd replace, otherwise don't bother. The bridge pins won't make a difference, replace if they are loose or worn.
A bone saddle will make the most difference. As mentioned above, make sure the saddle fits properly as well.
