If your planning on using samples to replace your drums, should that be kept in mind when setting up the kit. For example, the drums you plan on replacing with a sample, shouldn’t you think of it more as a trigger rather than a perfectly tuned resonating drum? Wouldn’t it be better if there were little resonance so that when a gate is used to reduce bleed a more defined hit could be created for accurate triggering. I plan on using Oxford Drum Gate, to clean up say, a snare track, and then send it to Slate Trigger 2 for replacement samples. I want the hits to be as defined as possible for trigger accuracy, so I’m not worried about tone or resonance, correct? Thanks
