czar of bizarre
ok here is the deal. i have music in acid. however i SYNCED acid with the roland vs. i used the vs as MASTER and i reorded the music into the roland. i laid down vocals to the music that was recorded inside the roland. now here is where it gets weird.
i burned the vocals and IMPORTED them as WAV into acid. i opened up the same song and i loaded the vocals up. for some reason it sounds a little off. i dont know what it is. it could be me but it sounds off. can i use the BEAT MAPPER to correct this?
if im not making myself clear let me put it like this.
i recorded the beat,laid the vocals and tried to match the vocals back up to what was inside the pc. keep in mind that the beat was SYNCED when i recorded it so everything should be on time.
the other problem is this.
when i record a source (spdif in) acid records my source AND the tracks that have been previously laid. how do i stop that?
another problem is jitter and sound play back. how do i stop it? im at 512 mb of ram and a kmd-k6 with 475 mhz and 2 hard drives. one is 5400 and one is 7200. if i record the tracks to the 7200 will that increase performence????
helpppppppppp
czar
helpppppppppp
czar
