brendandwyer
here's a new one....
first finished track in the new studio...
TravisinFlorida said:fabulous song. sounds well recorded and hey, the recording actually gets emotion across. that element seems to be missing around here more often than not. thumbs up for that. i'm iffy on the panning scheme and i don't think the solo guitar was up to par with the other performances. overall i like it a lot. vocals are great.
TravisinFlorida said:One more question if you don't mind brendandwyer. I hear a distortion over the entire track. It sounds good to my ears but maybe just a little on the heavy side. What is it? I think I'm hearing it on the drums and vocal mostly.
brendandwyer said:i had to up the gain once it was mixed down to the masterlink. it's the first time i used the gain render function and i think it distorted out a little. I won't be using it again in that severity
brendandwyer said:actually, i'm not sure that's the reason. and because of that i'm going to have to review it, because i don't like to hear that there is distortion i'm not fully aware of
TravisinFlorida said:it could be compression or a saturation effect? it reminded me of some of the saturation effects i've played with. it could also be my imagination.
thanks man.rayc said:The mix seems a little heavy to the left in my headphones.
Travis is onto the other matters.
Well done.
austinm08 said:Just a suggestion..
try a noise removal plug. Nothing major, but becomes a slight quirk when turning up the volume.
brendandwyer said:we don't use daw's to record, it's all outboard recorders and tape.
however, if i bring the mix into the box to pre-master it, i'll check out the noise.
But i do think that noise is an artifact of the gain increase in the stereo recorder, i'll check it out
TravisinFlorida said:maybe the saturation i heard was tape? did you track hot?
