Hi,
I recently installed a new sound card, an Avance logic 4000.
I run CB VST24 3.7 R2 on an IBM Aptiva with 64 Mb RAM, AMD K6-2 400 Mhz processor.
Now, whenever I try to record audio, the recording stops suddenly, which is not the main problem since it works when I redo.
The main problem is that when I play back audio, all of a sudden my left channel stops playing. (It still gives output in the monitor, but not in the master).
Yet when I check the WAV file in Cool edit pro everything seems normal. When I export a file however (a mixdown) and I check in CE pro, I have a bit of two channel stereo, but at some point my left channel is empty. I do not have this problem in other applications.
When I open Input from the audio menu and click on that, my left channel starts responding again for a little while.
Could anyone help me out here as this problem is extremely annoying.
Many Thanks,
Frankie.
Many Thanks,
Frankie.
