I started writing this thread but before osting it i read it and realized i was not making any sense!
So i will try to be more clear.
I have an external FX on a vocal track. An mindpirnt, Envoice's channel strip. Really like the new ''colored'' track better.
But i would liek t record it somehow! Not Mixdown it in real time, but record it. How can i route the signal of the vocal track so i would record it in nuendo session.
Can this be done!
In PT i use BUSSES, but i realize that nuendo and PT have the same words for a slightly different things.
example:
I have vocal track on one audio track. I insert some external FX, from outboard, letsay a compressor.
But i woudl liek to use the new vocal track the compressed one.
So i send it to a bus (imaginry, not the one with pshysical output) I then make a new audio track mute it, rute its input and ouput to that bus and press record!
And voila, i have the new compressed .wav in the project!
Its good for numerous resaons, especially for backing or if you have a lame DAW, and you need the CPU!
So my question is how can that be done (routing) in Nuendo, and i know it can be done with the audio mixdown.
I would just like to think there is another way than to mix it down, and then importing the wav back into the project!
Can this be done!
example:
