jaykeMURD
I sit on you.
I know I've grown awfully "happy" with the 60hz hum making itself present in my tracks. Of course, by "happy" I mean absolutely disgusted.
Anyhow, here's a bit of the scenario.
SDC (mono) to PAiA TMP 1/4 out to RCA IN on my M-Audio Delta 1010LT.
I know I'm running an Unbalanced signal chain, which will eventually be changing, but for the time being I'd like to record without that flippin' horn in the back ground. I mean, I've heard some AC hum in other things before, but this is utterly sickening. It RUINS any and everything I record. I try to EQ it out, but those frequencies are important!
I can hook my DMP3 up the same way and experience NO hum whatsoever. So it's not bad interconnects or anything.
I'm thinking the Power Supply on the TMP may be the culprit (as in many cases is).
I thought I might have developed a ground loop, but I've tried moving the power plugs around, but to no avail.
What is going on!?
What is going on!?
