AtoDeficient
I'm shopping around for a single-channel preamp. I have no need for a "channel strip", as my mixer has lots of channel strips and I have outboard compressors. . . I'm recording to tape, and therefore, I have the "warmth" already, but nearly every manufacturer is selling warmth these days, and as such, it's getting very warm around here. . .
Two that fit in my $500 budget are the Rolls Bellari RP520,
"It has the smooth yet punchy characteristics that drive vocal tracks to the front, warm up any digital mix, and yields up to 6 dB more gain before feedback for the live user. The pristine sound is achived by running the tubes at a high 250 volt plate voltage."
and the Focusrite ISA One
". . .renowned for its transparency, but there's also that subtle warmth that transformer core saturation contributes. This seeming contradiction of warmth plus beautifully open, unrestricted high frequencies, is a classic hallmark of the mid 80's Focusrite designs.. . .
With processors whose bandwidth is strictly limited to the audible (20Hz to 20kHz)
bandwidth alone, significant roll-off can still occur, affecting the higher audible
frequencies of the signal. Therefore, in order to capture every subtle nuance, exactly as it occurs whilst avoiding any roll-off, the pre-amp must operate over a far greater
bandwidth. The extremely broad frequency response of Focusrite pre-amps - close to
200kHz at the top end - guarantees accurate phase response across the much narrower
range of human hearing, the roll-off point being moved entirely outside of the audible
hearing range."
And so, they're different and the same. . .
Any experiences with these units? Any comments, technical advice, two cents, etc, is, as always, very appreciated. . .
hearing range."
