Lt. Bob
Spread the Daf!
well, they don't derate it ...... it actually only puts out that much power.Would the amp try (for lack of a better was to say it) to double but run out of supply or thermal capacity, so they derate it to reflect that?
But the reason is what you said, the power supply can't provide enough current.
So when you halve the impedance, it does 'want' to double the output but can only do so if the power supply will provide enough current.
Some amps do manage to double power output when impedance is halved and that's because they have robust power supplies.
I've seen audiophile power amps that'll double output down to 1 ohm!
But these are big money amps with huge power supplies ...... some of them will weigh over 100lbs and cost tens of thousands of dollars.
But typically, on the more modest amps we all have I see figures more along the lines of that CS800.
