Thanks guys for all the replies...My Mackie 1402 has a setting that gives you the option of Mic/ +4dB. Now I know that the output of a mic level is less than a line level, and I mostly use synths and sound modules. The Mackie goes into a Delta 1010. I have read the manuals for both, but there really is nothing more in each except to say that you can set it to either +4 or -10 dB. As most of you know, the Delta gives each input and output channel an option for either of these two. All my 1/4" cables are balanced(trs), and I know that say, an output with RCA's is going to be unbalanced by definition, but I've been running both Mackie and Delta at +4dB, and I haven't had a problem...just wanted to know if I was missing something. Sometimes the level on a channel without a trim is a bit low, even if the sound module's output is all the way up. I can easily bump up the level later in Sound Forge...but I would rather get an appropriate level going into the Delta to begin with. Thanks in advance for any more info.
