You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
OK. I need more XLR inputs than my trusty AudioBuddy can give me. 4 would be great fer instance.
Any thoughts on what I should consider ? All brands/types considered... AND I'm thinking bottom to mid end of the market
Big ta!
D.
Well I know "Nady" makes a Very Inexpensive 8 Channel Mic Pre in the $100-$120 Range... It is called the Nady PRA 8....
http://www.star-sound.com/Nady_PRA8.htm
I don"t know how good it is But it sure is Cheap and I"m sure if you don"t Crank the Gain too high you should get a Clean sound out of it....
Or you can do what I"m doing and Build yourself a Mic Pre amp....
Right Now I am working on Building a 2-4 Channel Pre amp and I have 2 Channels allmost Finnished so far and still need to build the Power supply.....
Cheers
