The Ashley's fall in that price range, and will work quite well on a monitor mix.
I would avoid using any graphic eq while recording though. Select a different mic, or move the mic position, or change the source sound to what you need for the recording. While mixing, I doubt that a graphic is going to offer any better control than a decent parametric eq.
But do check out the Ashley's for your monitor mix use.
Ed
