timothydog
I've searched and read about the whole 16bit vs. 24bit debate. 24bit is obviously the way to go if you can do it. But that is not my whole question here.
I would like to present my setup and maybe get some suggestions on what settings I should record.
I'm tracking guitars direct through an EQ pedal into a Pod 2.0. From the Pod, it's into my Roland 1680 mixer and then out the SP/DIF into my Audiophile 2496 card. It's then tracked to Sonar 2XL where all effects are applied.
So my signal is staying analog obviously until I hit the 1680 mixer. The specs say that the 1680 has 20bit D/A & A/D converters. So is this 20bit conversion a sort of bottleneck for me since I want to record 24bit with my Audiophile? If so, should I bypass my 1680 and go analog from the Pod to the Audiophile card? Or is that going to create too much noise?
Thanks for any help!
Tim
Tim
