Ok im having problems with sonar at the moment and i really need to convert a wav i have down so that i can send it as an mp3 to one of my band mates. If anyone could point out a way to do this then i would appreciate it.
* Hi...try changing the filename....make sure it has the correct file extension.
If that doesn't work....install another program that has the ability to record....play the file in the program that won't export and record the file in the one you've just installed......it should be xxx.wav [44.1] Then convert it to mp3
MAWD
