MessianicDreams
Why add EQ on the master bus when mixing?
Best to use EQ on the tracks to make the mix as good as you can then use an ME to add the finishing EQ touches (if needed).
I sometimes add a comp on the master out if it makes the mix better.
Eck (G)
I found that in my mixing I often wanted to alter similar frequency ranges. It might have been a room acoustic thing, I'm not sure. Either way, it worked very well for my. Unconventional yes, but fuck the rule book, this is recording.
Also, I'm a firm believer of sending the ME the best sounding mix you can. If that means a bit of 2bus EQ, the so be it.
