Ok going to listen to all your latest mixes. Can't wait.
As for the recording side it's not our mics that are a problem as only thing recorded with mic was the vocals.
I'll go through our whole setup to explain a bit about the recording:
Firstly the DAW we use is
ableton live 8. What I have found since recording is that if you put monitor on a track whilst recording there's a tiny amount of latency. Major bummer. Rerecorded bass track without monitoring and it seems tighter. Didn't want to rerecord other people's bits for them (though I am mainly a guitarist so could do some cheeky overdubs I guess
- The guitars and bass are DIed in through the USB port using ASIO driver. I'm using
guitar rig 3 for amp simulation though what I put in those wavs is the direct input from them.
- Drums are programmed by our drummer using Battery and the piano roll in Ableton. If you think they sound crap then it's probably more to do with the choice of certain drum samples as they're professionally recorded ones that come with the battery package. You mention the overhead mics, there is one drum sample (crash ride I think) that's annoying at the end. I will upload drums with that replaced if you would be so kind as to sub the Hats track.
Also your comment about doing each drum separately, well we can do that! Each drum sample is separately recorded. I just didn't want to output 20 odd drum tracks in wav format for ease of download for people mostly
Vocals were double tracked but it sounded like 2 people singing so only kept one of the tracks. I used double tracking effect on vocals in my mix along with a secondary track with a lots of reverb lower in the mix. I put all vocals through considerable amounts of compression and a tiny amount of EQ (de-Essing etc).
As for the mixing. I have been mixing in my kitchen or in the living room using headphones if the missus is working or on some fairly crap speakers otherwise. I know both are big no-nos but I'm not pro and have kids so can't crank it up any I'm afraid on decent speakers
I also high pass all instruments and vocals except bass at min 60hz though I high passed alot higher on some instruments. I did try and scoop out notchs in bass drum and bass to interact well. Not sure I did it quite right.
Going to try and do a rough recreation of your mix and see if I can copy it. If I can then I can add my own flavour to it. When I have done another mix I'll put it up here and hopefully you can say if it's ok
I can record a second rythm track with my guitar, will have a bit of a different sound. Do you think that would add to it? I'm not sure exactly what the lead was playing though some lead bits need tightening up anyway.
