Thanks.  No specs for the head gap, unfortunately.  Not even in the service manual.  But -5 dB beyond peak should be easy, because the service manual gives -6 over peak for several tapes, including 3M 256, Ampex 456, Agfa 528 & 468, etc.
I've been wondering if the gap is the same as other Studer machines, and since the Revox decks are only just barely disguised Studers it makes sense that the gap should be the same.  But I'll try to verify it somehow.
The real acid test will be setting operating level once the bias is set for 996.  I've been assuming that since it is a "mini-Studer" it should have no problem at all cranking up to a +6 or maybe even +9 operating level, with no distortion.  It is built, including the electronics, like a tank.  No, make that "better and more solid than a tank."  Do you think its record amps will be able to put out at that level?
