CavityCr33p
Hello! I work with computers everyday (my job, hardware specialist), but this little problem is pissing me off.
In my DAW, I have a Terratec EWX2496 pci sound card. I've been using this as the primary soundcard for recording and playback. The problem with this Terratec card is that it has lousy drivers. If you are using a program that has the ASIO driver open, and you try to play a song using the directsound drivers, you get a directsound error. This has always been the case, and Ive see this discussed elsewhere. They said that the asio drivers arent properly released. Anyways.
Here is the problem. I do my guitars in Adobe Audition (2.0 now) using the EWX Asio drivers, using realtime monitoring with guitar rig vst. I use fruity loops with DFHS loaded using ASIO drivers as well. Usually, the process is like this.
I do my guitars first in audition, mixdown, and save as wav. Ideally, I would be able to then, open up Fruity, load up the DFHS vst (using the asio driver) and be able to play the wav on winamp, WMP, whaterver, while tracking the drums in Fruity.
This cant happen tho, because with this soundcard, you cant use directsound and ASIO at the same time. Im trying to figure out another process to do this with now. I enabled my onboard sound on the mobo, and was going to use this for playback, and the Terratex for recording. Well, that works, minus the fact that I cant hear anything being recorded because unless I switch the main playback device to the Terratec card.
Any ideas? I know I could start using Sonar, or cubase, and do both the drums and guitars there, but Im so comfortable with Audition.
Im completely lost.
Im completely lost.
