Old 06-03-2006
Phyl's Avatar
Phyl Phyl is offline
Master of the Obvious
Phyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to beholdPhyl is a splendid one to behold
Keeping Snare Bleed out of Kick Mic
I recently got a drum set for the studio and have been experimenting with mic placement.
I've taken the resonant head off the kick and placed a D112 inside the shell, about 3" away from where the beater hits the head, pointed slightly off axis.
I'm getting some snare bleed into the D112. I've tried gating the D112 and using EQ, but still get too much bleed. It's not real loud, but enough so that when mixed in with the other mics it makes the snare sound thin. I've tried reversing the phase on the kick mic but that just makes the snare sound mushy.
Maybe it's the UAD gate I'm using...don't know...maybe there are better ones.
Any ideas? Would putting some sort of baffle between the snare and kick drum work?
Old 06-03-2006
slidey's Avatar
slidey slidey is offline
Happy Legs Fingers Davis
slidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond repute
I use the digirack expander gates & they work well for me................I would suggest that moving the mic away from the beater might be an idea also, over to the side a bit maybe.................away from the snare
in my experience it is almost impossible to remove bleed due to the nature of a drumkit. In order to punch the whole thing up & give more seperation try further experiments with your gates.......................if it makes you feel any better it took quite a while for me to finally feel at one with the gate as it can be a real mindfuck if treated wrong
I've never baffled any part of my kit to try & remove bleed BUT that's not to say some of the many threadsters havn't either
BOING!!!!!!!
G.F.C.G membership No# : 000 042
boingaroo aka wannabe drumber
Old 06-03-2006
RAMI's Avatar
RAMI RAMI is offline
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
Yes, like Slidey said, move the beater away. You'll probably get more low as a bonus by giving the air some time to hit the mic (probably not the most technical reason, but it will sound better
Old 06-03-2006
Phyl's Avatar
Great info; thanks guys.
Old 06-04-2006
big country's Avatar
big country big country is offline
Senior Member
big country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond repute
did you try pading the mic thats near the beater
Old 06-04-2006
Phyl's Avatar
I'm not sure I understand what you mean.
Old 06-04-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
The drummer is hitting the snare really hard and the kick really quiet. Tell him to stop.
Moving the mic back will help because it puts the shell of the kick between the mic and the snare.
You might also be using too much compression on the kick.
Another thing to try is put the front head back in the kick, put a hole in it and stick the mic just inside the hole.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog AND in .WAV format!!!
Old 06-04-2006
slidey's Avatar
D112 doesn't have a pad
BOING!!!!!!!
Old 06-04-2006
Farview's Avatar
A pad won't help bleed. It just turns down the volume of the whole thing.
Jay Walsh
Old 06-04-2006
Phyl's Avatar
I'm the one playing the drums, and your right, I was smacking the snare really hard and hitting the kick really wimpy. That's what happens when you put a guitarist behing a drum set.
I moved the mic back and evened out my hits; it sounds much better now.
Old 06-04-2006
slidey's Avatar
yeah I would've said that.................but............................well.......................................I forgot OK
glad to hear you're getting a better result
BOING!!!!!!!
  #12
Old 06-04-2006
jmorris's Avatar
jmorris jmorris is offline
livebandrecordings.com
jmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond repute
one question I have is why do you mind the bleed? But it really bugs you use a blanket in front of the kick and build the old drum tunnel thing,it help with all bleed into kick mic. Gates work well for me if I need them after tracking, little scarey during tracking in case the drummer kicks too soft.
People always seem to embrace the future then long for the past
  #13
Old 06-04-2006
Farview's Avatar
Bleed is good when the drummer plays with the proper dynamics. He admitted that he didn't. I've run into guys like this, it's not what you would think of as bleed. The problem is that the snare is louder in the kick mic than the kick is. That only happens when you beat the crap out of the snare and lightly tap on the kick. He doesn't have a mic bleed problem, he has a technique problem.
Jay Walsh
  #14
Old 06-05-2006
Han Han is offline
1K Silver Member
Han has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond repute
I once had to record a heavy metal band. The drummer was extremely loud on the snare and a pussy on the kick. Gating didn't help because the snare was even louder on the kick mic than the kick itself.
I ended up with triggering it from tape to Cubase and cut/delete all snare hits bij hand.
Next I used a kick from the Alesis D4 and the result was a couple of phonecalls from bands asking about that great kicksound, weird.
The alchemy of the masters moving molecules of air, we capture by moving particles of iron, so that the poetry of the ancients will echo into the future.
  #15
Old 06-05-2006
slidey's Avatar
exactly
some of my favourite drum sounds ever have been captured with 2 mics.................and that entails having a drummer that can play dynamically correct
BOING!!!!!!!
  #16
Old 06-05-2006
Farview's Avatar
When I run into guys like this, I just put a trigger on the kick and record that.
Jay Walsh
  #17
Old 06-06-2006
Senior Member
what the fuck is a pad good for ?if it doesnt stop bleed.
  #18
Old 06-06-2006
slidey's Avatar
mwhahahahahaha....................................lol...................................lmao........ ........................are you serious
it lowers the gain level so you can pick up a louder sound source without blowing your mixer pres through the roof
it's not going to stop other sources coming in which is what you apparently seem to think it does
BOING!!!!!!!
  #19
Old 06-06-2006
Phyl's Avatar
How would you do that? Seems like I've read about using the kick or snare to trigger a sample; not quite sure how to implement it in SONAR though.
  #20
Old 06-06-2006
Farview's Avatar
A trigger is a thing that you clamp to the drum. http://www.musiciansfriend.com/produ...5&src=3SOSWXXA
Jay Walsh
  #21
Old 06-06-2006
jmorris's Avatar
buy drumagog and make life easy
  #22
Old 06-06-2006
Senior Member
pad
dude you can also use a pad to lower the volume so the crap around you isnt as loud .a person who knows alot about micing drums will tell you to pad every drum mic to stop bleed that way it is also easyer to gate. trust me it works.
also a pad is good to use when you have real high SPLs
when I mic my kick some times I will pad it because the air blowing out makes
a crapy sound
  #23
Old 06-06-2006
Farview's Avatar
a crapy sound
Are you talking about a foam pad, or a line pad? We are all talking about the pad button on the board.
Jay Walsh
  #24
Old 06-06-2006
Senior Member
no Im talking about the kind you put between your legs once a month.
  #25
Old 06-06-2006
Senior Member
I know the difference between a fucking wind screen and a pad
a pad is not a wind screen or pop filter
Bookmarks
Calling all Metal (death) Heads!!! Bloodsoaked Mixing Techniques 45 04-18-2006 21:27
Best kick drum mic for many styles of music nuemes Microphones 18 08-23-2005 05:19
Unusual problem with mic bleed... name_goes_here Drums and Percussion 8 08-15-2004 17:16
How to get minimal hi hat bleed in the snare mic? DarthFaders Recording Techniques 8 05-09-2002 10:33
Help! I am plagued with Crappy kick and snare sounds... Uladine Drums and Percussion 9 04-30-2002 14:02
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1995-2010 Audiofanzine except where noted. All Rights Reserved.
