05-20-2006
hates cables.
Psuedo-mastering at home
I know just how important the mastering stage is, but my friend's band charged me with the task of mastering the album we've been working on nearly a year due to low funds. I've got an album worth of premastered waves in 32-bit (I don't think it's possible to mixdown to 24-bit in Adobe Audition or else I would have). I have some decent plugins at my disposal (such as the Waves Ultramaximizer) to do the job. One question I have for you mastering pros out there is should I EQ before or after squashing my beloved mixes into a brick?
Thank you for your time. It is much appreciated.
05-20-2006
independentrecording.net
I'm not a mastering pro per se, but in general the way I do it is
1. EQ to "fix" any glaring problems in the mix first, and to minimize any low-level frequencies that may wind up getting accentuated in an unwanted fashon by the compression/limiting process.
2. Compress to a wet brick (not quite yet limited solid.)
3. EQ post-compression just to polish or sweeten the results as necessary.
4. Normalize or limit the result into the final brick.
(and if it were me)
5. Throw the brick out and start over again, holding back on the limiting this time because bricks sound like crap
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
05-20-2006
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Absolutely. Do things that make it sound good *before* you do things that will inherently damage it.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
05-20-2006
Been Here, Posted That
Originally Posted by FattMusiek
...squashing my beloved mixes into a brick?
Smashtering.
Because we like pissing in our drink.
05-23-2006
www.masteringhouse.com
Every type of processing does some sort of damage to the audio. Either adding noise, quantization distortion, removing transients for the sake of overall volume, etc.
When putting together a chain try to figure out how you want to manipulate the audio, kind of like a ball of clay, and shape it into what you want (wether a brick or a ball).
The first thing that I would do (in general) is to remove any sibilance or plosives. So you can consider this EQ and/or compression. The idea here is that the threshold will change if you have anything before it, and it helps stop you from chasing your tail.
Next (if needed) perform any adjustments to the imaging (like M/S, or other stereo enhancements).
After any image adjustments strive for a good overall frequency balance. If there are frequency bands that are giving the mix a "lumpy" quality a compressor will react to those possibly in a way that is unmusical or at least not what you want in the final product. So EQ before overall compression is a good idea.
Next go for average level or adjust areas that are uneven volume-wise in the mix, usually with a compressor. I like to start with a low ratio and tune the threshold a bit higher than the average level, then adjust the ratio to make the mix as dense as desired. You may also have to re-adjust the threshold and other parameters to suit your taste.
After you have the mix sounding well-balanced in both frequency and volume, go for overall level if it needs it with a limiter or gain adjustment, then final in the chain would be to dither if you have completed fades and editing for the final CD.
It's not always the "formula" but works pretty well in general.
05-26-2006
Sound Advice
A few things to ponder
EQ prior to compression usually has a more buried effect as any significant adjustments are usually countered by the following compressor.
EQ post compressor usually has a more up front feel.
Linear phase EQ post compressor has a wonderful clarity to it as well.
05-26-2006
Senior Member
As a general rule of thumb, though, compression should
come after the EQ, correct?
05-26-2006
*Corrective* EQ, in general, should come before compression.
After that, it's up to what the source is asking for.
05-26-2006
Isn't all EQ corrective? Why add it otherwise? Please elaborate further on this John.
One reason to use EQ post compression is so that you don't have to keep re-adjusting the threshold of the compressor when making EQ changes. I'm not really keen on this and feel it's just laziness as it's my belief that the compressor should be acting on audio that is well-balanced throughout the frequency spectrum and the final intent of what the tonal goal of the music is. I.E. don't add compression until you have it sounding the way that you want. Adding two EQ processing stages when only one is required is adding unnecessary distortion. Less is more.
Another argument to EQ post compression is to make up for the loss of brightness when cutting down on transients. I can see justification for this.
Again, all of this depends on your tastes and workflow. If it sounds good either way, it sounds good.
05-26-2006
I mean corrections such as hiss, whine, sibilance, "thwumpies" and such - Things that you don't want *getting to* the compressor.
05-26-2006
Absolutely those can be examples. They are also examples of compression before EQ as well. For example sibilance is often fixed by a de-esser (essentially a compressor).
What you use and how you use it really comes to experience/taste and not just throwing up a standard chain.
BTW John I realize you know this stuff already, just bringing up points for the sake of the thread.
05-26-2006
Kinda' figured that...
| Thread Tools |
| Display Modes |
Linear Mode
