Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 06-01-2004
EleKtriKaz EleKtriKaz is offline
Home (w)Rec'r
EleKtriKaz will become famous soon enoughEleKtriKaz will become famous soon enough
Rode NTK Mods?
Just wondering if anyone has modified an NTK. I did a search and didn't come up with anything. Any thoughts?
Old 06-02-2004
still4given's Avatar
still4given still4given is offline
Got my ticket!
still4given has a reputation beyond reputestill4given has a reputation beyond reputestill4given has a reputation beyond reputestill4given has a reputation beyond reputestill4given has a reputation beyond reputestill4given has a reputation beyond reputestill4given has a reputation beyond reputestill4given has a reputation beyond reputestill4given has a reputation beyond reputestill4given has a reputation beyond reputestill4given has a reputation beyond repute
What kind of mod do you have in mind? Mine sounds great stock.
Blessings, Terry
Old 06-02-2004
Flatpicker Flatpicker is offline
Flatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond reputeFlatpicker has a reputation beyond repute
I've yet to see a <$500 mic (and often times higher) that couldn't benefit from upgrading the capacitors in the signal path. Replacing poor to mediocre capacitors with high quality ones does to your sound what cleaning your dirty glasses does to your vision.
Old 06-02-2004
Home (w)Rec'r
Yeah, it sounds great stock...I'm just wondering if it can sound better. Flatpicker, I don't know anything about capacitors...except maybe the flux capacitor...but that probably won't help in this case.
What kind of capacitors? Is this easy to do? How much do capacitors cost?
Thanks for the info
Old 06-02-2004
Simply put, capacitors are used to couple one part of an amplifying circuit to another because they block DC and pass AC. In an amplifier, whether it be a mic head amp, preamp, or power amp, you have a DC voltage, which powers the thing and an AC voltage which is the signal you are amplifying. When the signal passes from one stage to the next, the capacitor keeps the DC on the previous stage from entering the following stage with the signal (this would screw up the amp real bad).
Think of it like this – If DC was the water in a river and the signal was a boat, a capacitor would be kind of like a dam with a lock that lets the boat go from the higher water to the lower water with out harm. Notice I said “without harm”. If the lock were poorly constructed the water might run out too fast, or it might be too narrow or something – all of which could damage or “distort” the boat.
Caps work like this too. Some types pass signals with less distortion than others. By distortion, I don’t mean the kind you hear from an electric guitar. I simply mean the signal isn’t exactly like it was before it went through the cap. We might hear this as a smearing of the highs, or maybe a less “clear” sound. By replacing these caps with better ones, the signal can come out the other side like it went in..
Most low priced condensers skimp on the quality of these components. The cost difference is only a few bucks, but the sound improvement is tremendous! But, if you spend $5 in Chinese parts it equates to about $100 in retail price (about 20X), so that’s why they don’t do it.
The trick to replacing caps is knowing which ones to change and to have enough experience so that you don’t rip traces off your circuit board in the process. It’s not all that hard, but then again I know some inexperienced folks who have ruined good boards, so it’s best to practice your soldering skills on an old radio or something first and get good at removing parts with a solder sucker and solder wick.
A schematic would be best, but if you could post some close-up pics of the Rode’s insides, someone might be able to tell you which ones to change.
Old 06-02-2004
riley357's Avatar
riley357 riley357 is offline
HR MUSE
riley357 has a reputation beyond reputeriley357 has a reputation beyond reputeriley357 has a reputation beyond reputeriley357 has a reputation beyond reputeriley357 has a reputation beyond reputeriley357 has a reputation beyond reputeriley357 has a reputation beyond reputeriley357 has a reputation beyond reputeriley357 has a reputation beyond reputeriley357 has a reputation beyond reputeriley357 has a reputation beyond repute
I did a Google search for "Rode NTV mods" and came up with a guy that was replacing caps in NTK's.
He is also replacing the Jenson transformers in NTV's with a custom-wound transformer of his own design, which doesn't seem like a very good idea to me.
Slainte
Riley
Old 06-02-2004
Got my ticket!
OK, I did the Google search and I think this is the article you spoke of. You have to pan down the page to RODE. Since the NTK has no transformer he didn't change that on the NTK. From what I read, he says the RODE mics are pretty much "state of the art" as they come from the factory. He said he got the most change by changing the tube, however this mainly reduced some "compression" he was hearing, which you may or may not like.
Blessings, Terry
Old 06-02-2004
c7sus's Avatar
c7sus c7sus is offline
Disenfranchised Member
c7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond repute
Yeah, that's the guy. Did you look at those preamp kits? For $600 I think the guy could do a lot better than a fucking breadboard.
Old 06-04-2004
Rossi's Avatar
Rossi Rossi is offline
Dedicated Member
Rossi is on a distinguished road
I haven't seen a "naked" NTK yet, but I've examined the newer NT2000 and K2 models. I don't suppose there's anything in there that should be upgraded. The NT2000 (solid state) has SMD electronics. So it would be very difficult to mod anything. Fortunately, the electronics look high qualiy; actually very impressive. There's film capacitors, btw. The K2 looks very solid, too. The elctronics are much simpler, but just as clean. To my eye, Rode's electronics are as good as it gets these days.
Old 06-04-2004
Middleman's Avatar
Middleman Middleman is offline
Professional Amateur
Middleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond repute
Sell your NTK, buy an NT2000. Best thing you could do with your time and money.
This is just a test
Old 06-04-2004
Home (w)Rec'r
sounds great middleman...this thing is a piece of crap anyway...
  #12
Old 06-04-2004
c7sus's Avatar
Send it to me. I'll even pay the shipping.
  #13
Old 06-04-2004
Home (w)Rec'r
Smile
I was just kiddin'...I love my NTK...it's my only mic for the time being. I don't know what I'd do without it.
  #14
Old 06-07-2004
Dio24 Dio24 is offline
Newbie
Dio24 is on a distinguished road
Just out of interest...does anyone out there own an NTK and a K2? Have you compared the circuits? From what I can see they are very similar. I'm interested in finding out how exactly they differ.
  #15
Old 06-07-2004
Middleman's Avatar
They are not the same, first of all different capsules. There is significant differences in the circuit based on the variable patterns and other features not found on the NTK.
Do they sound the same? I don't know, but I will in a few weeks!
This is just a test
  #16
Old 06-07-2004
Newbie
I just found it interesting that the new NTKs are being produced on the K2 circuit board.
  #17
Old 06-08-2004
Hmmm... sounds like the K2 is just a multi-pattern, dual diaphragm version of the NTK.
  #18
Old 06-08-2004
Newbie
Well isn't that why its called the K 2?
  #19
Old 07-26-2006
comandante comandante is offline
Newbie
comandante is on a distinguished road
Вump!
I was searching for NTK's schematic and found a hand drawn one at
DIY Factory
This guy's mod was all about replacing caps. What I am interested in is modifying circuitry to eliminate the two humps at 5 and 12 khz that are responsible for NTK's glare many people are unhappy about.
Any of DIY gurus to look at the diagram and tell which circuit might be in charge for high frequency boost?
  #20
Old 07-26-2006
Gus Gus is offline
Junior Member
Gus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond reputeGus has a reputation beyond repute
the chart has more to do with capsule and the capsule grill interaction than circuit design or cap changes.
There is more to what I did then what I gave away: however the capsule/grill EQ is still there.
Now I have a modded nt1000 and a modded K2 the NT1000 sounds better at a distance( I think it is the same capsule as the NTK) The K2 seems to have a different "tuning" with its capsule it also has a different grill. I like my K2 it sounded OK stock I am not a fan of the 6dj8 in standard microphones so a different tube is installed in mine and a few caps changes.
  #21
Old 07-27-2006
Newbie
I also changed the tube to NOS and did some cap work on my NTK. The sound got softer and cleaner but the original essy character is still there.
I doubt that the boost only has to do with cap/grill design. At least K2's chart is all the same, exactly with the same peaks.
  #22
Old 07-27-2006
Gus Gus is offline
Junior Member
First I did not use a nos 6dj8 type (6922 etc)
Why do you doubt the capsule grill part?
FWIW I have two microphones with the same simple 1 fet circuit I built. The FETs were matched IDSS bias up with the same value resistors etc. I sort them from a bag of 1000
Same type 32 mm MXL capsules both from v67s I bought at the same time. One in a v67 body grill, one in a piece of machined fence post differnet Dia and grill open area. Sound very different if I move the capsules the sound stays with the body grill.
FWIW I post about stuff I do/did
SP wrote about posted about grill capsule interaction years ago. If you look at neumann microphones look at the grill designs. Look at a 414 grill.....
  #23
Old 07-27-2006
PhilGood's Avatar
PhilGood PhilGood is offline
Juice Box Hero
PhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond repute
I would listen to Gus about this stuff.
I've followed his work on other forums and he knows exactly what he's talking about.
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life."
  #24
Old 07-27-2006
Gus Gus is offline
Junior Member
I should add don't believe me, test it yourself. I mean this in a good way.
I don't trust what I read on the web. So if I can test something I will. I bought a brauner VM1 just to learn. I have bought other cheap/expensive microphones just to test/learn I bought a K2 to check it. Then I bought a lathe and started to make parts to build microphones. I have also worked on some friends very good microphones.
IMO most of the sound is linked to the capsule but microphones are funny it seems every thing counts.
  #25
Old 07-27-2006
Newbie
You know "souns different" is pretty vague term. If we change a part of a mic and it sounds different, how can you tell that this subtle change is exactly that peak at 12 khz or is it something else. Judging on listening or measuring are two different worlds. Did you measure the freq responce?
I have no expirience with K2. Can you tell me, why K2's and NTK's charts are virtually the same if they have different capsule and grill design?
I'm talking about a 6 db peak at 12 khz. Which part of 1'' capsule can produce such a strong acoustic resonance?
After all, modding is a tricky bastard. You can't AB compare what you had before with what you have. It's that easy to fool youself
PS I like your never-trust-what-the-others-say-try-it-yourself attitude
