I am bringing it to my buddy. It will take him fifteen minutes to find the problem. I will post the results when I get them. Thanx. The component I don't know what it is sits on the heat sink, which is actually part of the amp chassis, right between the two output transistors with two wires coming from the transformer with 120V on each. I pulled the output transistor that is not getting any voltage and checked it, it checks good. One output transistor shows voltage applied and the other no voltage.. The output transistors are 36892s or substitute 2N3055The are probably over 100 variants on the transistor power amp circuit Dogs' but the principles are pretty common so I might be able to help. Let's dispose of that "thermostat" first of all! I am sure that will be a re-settable* Thermal cut out. They usually look like small control knob with two 6mm spades on it. Usually attached to the main heat sink but might be bolted to the power transformer. You have 2X 40V so that we can ignore.
There will be two power transistors, might be metal cased or plastic tab. Somewhere close to them will be the emitter resistors, usually quite big 5W types. Inspect them for signs of distress then measure them...COLD! They are likely 0.22 Ohms. If they are 'blown' then so are the transistors and probably most of the other devices on the power PCB. Fixing transistor power amps is a PITA. But, since you have not reported 'smoke or bang' I suspect you could just have a disturbed wire or bad joint.
Can you attach some photos and then we talk again?
*They usually reset once 10 or so dgrs below 'trip' temp' but some need a blast of freezing spray.
should look similar to a relay, look for a black box. The relay stays energized as long as the thermistor is with in parameters.used to working with transistors and don't think I ever ran into a "thermostat" before?
The thermostat has no problem.should look similar to a relay, look for a black box. The relay stays energized as long as the thermistor is with in parameters.
I use F5 fader lube from Deoxit, contact cleaner can be aggressive on the control, but if I'm down to that level, I change it out with a sealed pot.My money says the the cleaning fluid is actually an insulator, and got in places it shouldn't.
