Violin sound.
I remember the days of Zeibart, Rusty Jones, and others. That was one of the many "dealer upgrades" that you paid for, along with pin stripes and floor mats. American cars in the 60s and 70s started to rust the day you drove them off the lot.
With the way cars are dipped and painted today with electrostatic primers, sealant and paint that contains corrosion inhibitors, you don't see much demand for such systems. I don't know much about Skoda. I had my Acura Integra (Honda) for over 20 years, and there was just a small amount of bubbling by the rear wheel wells. Structurally, it was solid. The only issue when I sold it was that the rubber seal around the rear window started to leak in one spot if you had a really hard long rainstorm. My 7 yr old Ford Taurus look almost perfect, although for the past 5 years, it's been garage kept.
Colin, how long does the coating you are using last? Is it something that goes 10 years, or more like driveway sealant that starts to peal off after 2 years?
Hi,
Thanks Raymond. Normally we'd trade in against a new car every two or three years but this Yeti has changed things because we like it so much so want to keep it; next years service it will require new front brake pads and disks which is disappointing; brake pads yes no problem but new disks needed at 32,000 miles? I drive using the gears so am very light on the brakes.
Thanks for asking TalismanRich. It's very difficult to say how long this rustproofing will last because there are so many variables; dry dusty driving I'm sure will wear it away more than just driving in the wet also those who go off-roading will wear the bottom areas out; we only drive short distances so it should last a long time but it's easy to check each year once it's been applied and do a bit of touching in; I'm 76 this month so if we can get another 15 years out of our Yeti I'll be delighted; next year if it costs £1,000 for service and brakes etc it's cheap motoring for a year; it's always main dealer serviced and always run on best diesel. Look at the depreciation of electric cars; I can buy an awful lot of spares for such an amount and depreciation on our Yeti is virtually zero in fact it's holding its value.
Italian cars of the 60's were about the worst for rusting; remember the Alfa Sud? It rotted as you looked at it; I wonder how many are left.
I got up early this morning in order to rustproof the final wing but having just had breakfast our dire Yorkshire climate stopped me as it started to rain so I've cut the grass instead.
Yesterday evening I enjoyed a violin practice and today I think I'll enjoy two practices; it's pointless fighting the weather but it frees up time for me so all isn't lost.
Kind regards, Colin.
My Taurus is now just over 75,000 with original brakes and two of the tires are original. I replaced one pair when I caught the edge of a drain and it cut the sidewall of the tire. I could have gotten by with one, but I don't like to have mismatched tires on one axle. Treadwear is still good. Just last weekend, I took a 700 mile trip, and was getting around 33 MPG, until I got to a construction area where I basically crawled for about 30 minutes to go a couple of miles. That kicked me down to 30 MPG.
Colin it's funny that you mentioned Italian cars. In the late 70s, a fellow that I worked with bought an Alfa Romeo Spider. It was so temperamental that we used to tell him that if the weather forecast was for showers later in the day, the car would refuse to start just so it wouldn't have to get wet! After about a year of fighting it, he had a shop pull the stock electrics out and put on some Bosch replacement parts. After that it became much more reliable. It was a fun car.
The old MGBs and Triumphs were also fun to drive, but I remember the guys who had them always seemed to have oils spots in the driveway. I came close to buying a TR4, but ended up with a Capri instead. It was a decent car but had a few issues.... One night the bolt that held the harmonic balancer on the crankshaft came out and was tossed up into the hood, leaving a dent. I tapped out the end of the crank and put a hefty bolt in there, and never had another problem. The shifter literally broke off in my hand, twice! I could change the shift lever in about 15 minutes after the first one broke. The seat backs for both the front seats broke the rivets that held them. I fixed them by putting in 1/4" bolts with the heads ground down so the recliner mechanism still worked.
The funniest part was that after I traded the car in on my RX7, I got service recalls because a) the shift lever could break off and b) the seat back could unexpectedly break causing an accident.
Hi,
Thanks TalismanRich for your interesting story.
Italian cars were always noted for being temperamental; I've never owned one and I don't think I've ever been a passenger one. Some nice looking cars though.
British cars & British bikes used to wet themselves usually dropping oil from the rear crankshaft bearing seal on the cars but the bikes used to have their crankcase split vertically unlike the Honda's which came into the country; I assembled some of the first Honda bikes to arrive here in the UK; I used to repair and restore many bikes but the first Honda I worked on really impressed me; it was very nice indeed to see the crankshaft and gears nicely laid out. Honda's also had indicators and electric start. on the 250's if my memory is correct; British bikes involved kicking off and arm waving no wonder Honda quickly caught on; the only electric start bikes I owned were BMW 750's. I had an older model of the Vauxhall Viva which like your Taurus used to break its gear lever but it only took minutes to replace.
Yesterday I enjoyed three violin practices and two practices today in fact I think I can make it three; I'll wander into the studio.
Hi,
Thanks for asking rob; yes I'm about ready and also want to complete the songs I'm already playing; I can play large sections but as yet not the complete scores; there are so many things in my life pulling me in all directions by the time I do get into the studio I don't know whether I'm coming or going; I managed another three short practices yesterday; I'm currently popping into the studio switching on the violin with amp; playing the same songs then having to leave the studio in a short while; it's not what I expected when I first wanted to learn playing a violin but it's just the way my life is with little control.
My wonderful wife has four hospital appointments and a doctors appointment involving more scans then comes waiting for results followed by more appointments; with her being so unwell I'm doing my best to help her but it takes up a lot of time which I'll never begrudge or complain about I just roll with it. On top of lots of health issues my wife might now have Parkinson's; it does stress and upset me to see her so unwell.
I'm rustproofing our car and have just strimmed our meadows; shopping; ironing; doing the dishes; helping out with some cooking and baking; hedges to trim grass to cut; it just goes on forever hence slow progress with my violins; in spite of everything I'm basically happy because at the age of 75 I'm still climbing and felling huge trees; I'm just pleased I'm well enough to hold our lives together and to fully support my wife as she does me.
Chin up and just get on with it; moaning or getting depressed won't solve anything; days used to fly by but now it's years which fly by at an alarming pace; two years ago I hadn't touched a violin but now I can play six tunes; not perfectly but recognizable; I'm happy with my progress so far but it's hard won.
Strimming is hard on arms and not good for violin practice afterwards but I keep trying.
Time now for breakfast then another busy day ahead. My wife will always come first; I love her to bits.
  • Love
Reactions: TAE
Hi,
Thanks Raymond. (y)
After a very busy day yesterday visiting the hospital etc after tea at around 6 o'clock I indulged in a short but pleasant violin practice.
Next onto the computer to catch up with mail but before doing this out of curiosity I thought I'll just check my blood pressure; I was absolutely horrified to find it was 64/47 with pulse at 60. Was I about to suffer a major stroke? I then took it easy until bedtime at 10 o'clock when I took another blood pressure reading; it had climbed but I forget the reading.
Before breakfast this morning still upset I took another BP reading this time it was 118/64 with pulse 60 which pleased me no end.
I only have a light tea having had full dinner at dinnertime; two slices of dry seeded bread and a nice small piece of cherry cake then the violin practice; I'd been on the go all day and was worried about my wife but also my arms and hands remained stiff from working on the car; it's possible having food before taking the BP reading upset the result; normally my BP is bang on in fact excellent given my age and even when I've been doing very heavy work it settles down after a few minutes when I come indoors; I hope it was a fault with the BP monitor which is a possibility but I'm regarding it as a warning.
I'm just enjoying a mug of tea then I'll wander down to resume rust proofing the car whilst we have a rare warm dry afternoon.
I keep practicing whenever I can; every little helps.
You had BP of 64/47? That wouldn't cause a stroke, but it could sure make you light headed from low pressure. 118/64 is about perfect. Now if you had said 164/147 then I would say Yeah, you're a candidate for a stroke.
I've had my BP tester go weird a few times. The doc checked me out in the office the other day, and it was 124/84, so I guess I'm still ok.
With temps in the mid 90s and dew points in the mid 70s, I didn't bother going out much yesterday. I think we have 3 more days of this crazy heat and humidity. I'm glad I got all my outside stuff done Saturday. After an 8:30 tee time in the morning, I got home and thought it would be better to cut the grass while it wasn't too hot, then worked with my son-in-law to cut some lattice work to put around the base of the shed. Finished up around 8:45 that night. He put the finishing touches on Sunday morning.
I Hope you're feeling OK - On the practice front, I noticed you say this "I can play large sections but as yet not the complete scores" - I suspect that you have fell into the habit of practicing the bits you can play, If you can play some of it, then do NOT waste time playing these bits. Start with the stuff that causes problems. Then when you've mastered the hard bits, the easier bits are simple. With the music you are using, you should, with your dilegent practice routines, have got to the end by now. There's no point practicing the parts you can play, and ignoring the bits that stretch you! I stringly suggest doing a little 'audit'. Which bits can you not play? Analyse these bits and work out what the barrier is? Note identification? For some reason is there a note that when you see it does not automatically transfer to a finger position and a note letter name in your head. As in, see a note, declare it as a high A, then finger the high A position on the right string. Identify progress. Snail's pace, slow, moderate or fast? If you are making little or no progress on a certain but, then dump that song for now, and try something new and see if the speed increases. I know you saiud you have a poor memory, but I suspect it's better than you think and your fingers are not really struggling - it's becoming too easy for progress. The hard bits then become barriers. Find a new piece of music and start again. By now, if you've not yet got to the end of the piece in one session - dump it.
Hi,
Thanks TalismanRich; my BP readings really did frighten me considering I've had perfect readings until this low one; I'm not obsessed with taking BP readings but about 6 months ago I was invited to the surgery for a BP test and it proved borderline high so the surgery nurse booked me two appointments; I was to be fitted with a monitor then the day after return it. Just before having the BP test I had lots of trouble driving to the surgery; City cable had all the local lane dug up with a number of three way traffic lights as usual they all went Amber/Red so I was sitting sucking my thumb for ages then parking at the surgery is abysmal. In the waiting area a small girl about five years of age was screaming so loud it really went right through me; much louder and more piercing than any of my machines; it rattled me but I did feel very sorry for the poor little mite who obviously was hurting a great deal; the outcome my BP was high.
Returning home I knew what had happened so I bought online a Boots BP monitor and used this recording at various times over a week then I submitted the readings by letter visiting the surgery when it was closed and posting by hand; I received a phone call saying I was fine and both new appointments were then cancelled this is why I now have the home monitor.
What a shame to have such a lovely shed outside it looks top notch. Has it been painted using Benjamin Moore paint which I use. (£100 per US gallon here in the UK and a US gallon is quite a bit smaller than our Imperial gallon).
I fully understand what you are telling me rob and in a normal life yes I could follow your excellent advice; I don't know if I'm even on this planet at times due to so many pressures exerted upon me. I do admit I'm playing the same tunes over and over but better this than not playing at all; I'm unable to concentrate when I go into the studio always with a feeling of pressure to be somewhere else; I'm sure you'd understand better if we could swap places; I'm deeply worried about my wonderful wife who has so many hospital appointments; one already attended this week with another on Saturday; next Thursday two more appointments and now also two doctors appointments at the surgery with even more to follow as results from scans and X rays are ready. On top of this I'm doing so much around home and gardens; I've been working on the car this morning until now.
I'm expecting a new petrol mower to arrive today; our car received an "Amber" on the July service sheet it needing new front brake discs & pads; main dealer price £334 I'm now going to visit a local Ferodo stockist to buy genuine Ferodo parts not relying on eBay where non OEM parts are supplied in boxes looking as if they are genuine; I'll not compromise on safety or skimp on any job I do.
Our next door neighbour sadly died last Wednesday he was a friendly guy he and his wife retired only living here for three years; across the street our lady neighbour has been in care for two years her house and gardens neglected; the other next door neighbour is very frail indeed at 88 struggling using two walking sticks; another neighbour has suffered a seizure; my wife too is very unwell; it's all so depressing but I do at least try to get into the studio; I could have had a practice instead of typing this but it's pointless as usual my arms and hands are tired and stiff after working on the car. I do want to learn to play my violins but unfortunately they are down the list regarding urgency.
I'm tired and worried.
Hi,
Just an update to once again say a huge thank you to everyone who has helped me so much and to those who have taken the trouble to follow the thread.
Ever since my wonderful wife treated me to my first violin I've constantly struggled to get time to play it; things are currently much worse I've not touched my violins for over a week or even been into the studio. I've so much pressure on my time with bungalow & gardens maintenance; household chores etc; my wife deserves a better quality of life being ill for over 40 years but now sadly she has lots of other health issues; we've been tied up visiting four hospitals recently including 3 MRI scan; Cat scan; x rays etc; she is being tested now for Parkinson's disease; it's not life threatening but mobility is increasingly limited.
I get out of bed early every morning blink and go back to bed the days & weeks just flying by at an alarming pace. We fully support each other and in spite of all the difficulties remain cheerful making the best of life.
I'll never pack in or sell my violins or studio gear hoping to eventually have a bit of spare time.
Thank you once again.
Kind regards, Colin
Sorry to hear the news about your wife. Hopefully the Parkinsons diagnosis comes back negative. It's a strange disease. My dad suffered with it for about the last 5 years of his life. He could move around just fine, but if he looked upward much, he completely lost his balance. He never had the shaking that some people experience. but gradually it slowed him down. Something as simple as looking up to walk up steps was a problem.
The good thing about your violin is that it will wait for you. My guitar sat for a good 20 years before I pulled it out and started playing again. Now I pick one up just about every day. Even if it's just a few minutes to relax and calm yourself, it's worth having. Music is good for the soul.
Today I spent an hour playing my cello. That makes a total of two hours since 1972. My brain is way ahead of my fingers, but in that hour, I made serious progress. I just bought a nice guitar because my old acoustic had some very honky resonant notes. My guitar playing has NOT improved I note.
The whole point of music is to get better at it, at any speed in any way you can. My grandson is at the new big school, and today he had a piano lesson, because one of the teachers heard him playing - he says it was the best lesson yet! Music can be hard work, but also decent therapy from life stress.
Colin - just look after the wife. Her needs come first, as you're doing. All these nerve transmission illnesses just stop you doing nice stuff. Do what the docs suggest and go from there. PS no more trees, or digging, or chain winches - that is something other people can do for you, and isn't really good for you.
You have your priorities right, Colin. Attending to Bron has to come before anything else.
My own experience was 15 years of accompanying my mum through alzheimers, and looking out for her interests.
But she was in a specialist home, with professional carers. My contribution was being with her, and playing in a band for all of the residents.
It can be hard when it is all down to yourself.
Whatever health challenges you have to cope with, there will be good days in with the bad days.
You have to make the most of the good days.
I hope you can check in with us, occaisonally, even if the music is on hold.
Hi,
Thank you TalismanRich for your story I'm sorry to learn your dad is no longer with you. Bron's been put on tablets which should stop her hand shaking if she has Parkinson's; one tablet per day first week two tablets per day second week and no more than three tablets per day third week at the moment she's half way through her second week with zero change in her hand shaking; if the tablets don't work then it's something else so we need to wait and see. Amazingly I managed 30 minutes this morning playing my violin; I'd got Bron settled with glass of water; mug of tea and hot water bottle she was comfortable stretched out on the sofa watching a movie. I think violin playing must be similar to riding a bike once learned never forgotten; I played my usual pieces without much difficulty once I got going.
Thanks rob; wow you're really going hard at it playing your cello; I agree music is excellent to get away from stresses of life; I just can't get away; today was the first time I touched my violin for quite a while. Two weeks ago a skip was delivered directly across the street from us resulting in a smashed cast iron manhole cover on the pavement in front of our garden wall; the driver owned up and did the right thing; a new cover was quickly fitted. On Monday morning this week the full skip was collected to be replaced by an empty skip. At 1pm our former neighbour visited us and said have you seen the highly dangerous manhole in front of your bungalow?
This time the damage was severe; the new cover was smashed but also the brickwork badly compromised the wagon had destroyed the manhole but the driver had scarpered not saying a word or reporting it. I took digital images of the manhole and also copied a few slides from our CCTV showing the wagon on top of the manhole. I sent a friendly email to the skip company together with four pictures; another skip wagon was quickly here the driver a different one to the previous two and he said surely whomever did this would be fully aware of the damage but he hasn't reported it; the debris was cleared and a large cover placed over the hole with a traffic cone at each corner now at least it's safe. I didn't have a coat on so it poured with rain and I enjoyed a soaking. Myers were excellent.
In the evening it was dark when Yorkshire Water arrived to assess the damage and put in a report for repairs; I went down in my "Site" coat but received a very nice soaking as the rain bucketed down.
All last week I was on the keyboard in total frustration with unethical Virgin Media. Our bundle was to increase from £61 per month to £78 per month and if we didn't accept we had to cancel before a certain date. We only have a landline phone supplied by VM so I phoned VM to cancel the contract when it expires; I selected option 1 accounts and was then told to add my mobile phone number? I don't use a mobile phone so how could I do this. I tried their 150 & 0345 numbers but received the same request so I couldn't contact VM from our landline. I then spent an hour and an half waiting to be connected to their chat line their timed estimate being 63 minutes.
I offered to pay the £61 to extend our current deal but this was rejected the new price firm at £78; I requested our account be closed but was then transferred to another chat line in order to discuss this with a supervisor; in disgust I closed the chatline I'm 76 and was rapidly growing older. I thought I've had enough of this Bron and I having been NTL/VM customers for over 30 years; I decided to try BT who have an 0800 number where I can use our landline to speak with a human being not a robot. I decided to try BT chatline for comparison; amazingly an immediate connection; 45 minutes later Bron and I are now agreed to a very similar bundle with BT but this new bundle doesn't include evenings or weekend free calls which doesn't bother us at all but BT do include basic Netflix and as a bonus one month free sped boost. Cost £47 per month on two year contract. The guy at BT was top class.
For £5 per month extra we could have powerful WiFi with guarantee no loss of signal so we accepted it making the bundle now £51.99 per month. This was exceptional customer service; the day after I received an email from Netflix requesting I open an account with them the cost charged to BT; our new BT installation starts on the 12th so now we already have Netflix even though no bank details had been supplied. Brilliant. I supplied the bank details today having received a letter from BT.
Having sorted this out then we received a phone call on our landline from VM an actual living lady wanting to discuss VM best bundle deals; I explained we'd agreed a new two year contract with BT then she asked how much our new BT deal was I stated £51.99; after a pause VM could now offer our current bundle for £54 per month; my reply was Bron and I are old fashioned our word is our bond and we never ever go back on a deal saying it was highly unethical of VM to even suggest such a thing; once again I requested VM account be closed she said she would close it.
The account wasn't closed so now I went onto Virgin Media Community Forum stating exactly what had occurred; an 81 year old member was having exactly the same difficulty closing his VM account but offered me sound advice; do not cancel your direct debit payments to VM it could compromise your 100% credit rating instead write and post a letter special delivery stating your contract be terminated which I did the letter costing £6.85. Next I received an email from VM letting us know our new bundle was arranged and we didn't need to sign for it? Just how low can this VM company sink treating customers like dirt in this manner; all this story is posted on their community forum; this is just some of it the problem which tied me up for a week when I already have more than enough stress in my life.
This afternoon I received a phone call to say my younger brother had died; we weren't at all close not seeing each other for over ten years; he had a bank account with money in it and he hadn't married his long term partner so she wasn't entitled to claim anything; I thanked the lady saying please give the money to his partner I don't want any contact with my family of vultures at all; I was asked to put this in writing which I declined saying absolutely no contact and I won't be attending the funeral; my family totally ruined Bron's wedding day then for years tried to come between us; those who stole my share of my late mothers detached bungalow can now pay for the funeral; I've got only one person in my life I fully trust; my wonderful Bron the rest can get lost I'm not interested.
Yes rob Bron comes first and I'll do my utmost to look after her; regarding all the heavy work I still carry out it keeps me fit and active just what Bron needs allowing me to look after her; I'm not the normal type of guy who retires and gives up I'm super active and hope to remain so for years to come but I understand what you mean.
Many thanks Raymond; yes Bron is number one priority in my life and always will be; you well understand the problems associated with someone ill; thanks for your kindness as you say good and bad days but even bad days are good I still have Bron and until one of us passes away this is the way it will be.
I just wish we'd be left well alone to enjoy our lives together without constant problems day in day out without any let up; I'm not complaining because I've got Bron to make it worthwhile getting out of bed each morning.
Thanks again everyone for your kindness and support I truly appreciate it; I'll now settle down to a movie before bedtime with Bron; we've now got Netflix to play around with. I'll pop back on time permitting.
I feel your pain - I've been with EE for ages - at least 25 years - they increased my phone contract by £15 a month in April and I didn;t notice till I got a text saying my unlimited data had been removed - I waited an hour on a queue and they told me. The rep said he had never known them to randomly do what theyve done and I got a reduction - not to what I was paying but close.
My home is on fibre - Lowestoft got every pavement wrecked by city fibre - often numerous times and I moved from BT to their system. Didn't realise that fibre doesn't include a phone, so as it's a business line, it's now a VOIP service and redirects to my mobile if I am not at home - but I pay for fibre at home and the office, and two voip services - three website providers, online storage, email and the list goes on. It's so complicated now!
I hope the manhole gets sorted out. We've got some famous ones in Gt Yarmouth still.
T Crapper & Co.
Several years back, Google Fibre came into the city. They embedded the cable on the edge of the roadway in a few parts of town as a start. However, they were doing "microtrenching" which made something like a 6 inch deep x 2 inch wide trench. After they laid the cable, a asphalt/rubber sealant was put into the trench. All was well, until the sealant started to pop out of the trenches all over town. Big rubber ropes were being pulled up. That led to the next problem. Snow and rain went down the trench, froze and started to make instant potholes with the winter freeze.
t
After 2 years, Google pulled out of the city, and paid to have all the streets that were affected repaved. However, we still get little "cave-ins" along the edge of the road in spots. They went back and filled them with tar. We'll see if it holds up another winter.
So for now, we get all our cable and internet off a pole... as God intended! 😜
I am about to order a cast-iron sewer inspection cover, for outside the shop. They are rated for various weights.
I'm thinking 5 Ton, which shoud be good for cars and small trucks.
They do a 25 Ton version, and I guess that would cope with a loaded skip truck.
I once had Sky satellite TV, but they kept jacking up the price, and I was working away from home anyway.
When I tried to cancel it, they kept passing me from pillar to post, with a series of different people trying to talk me out of it.
