I inspected the wiring from the heads, and found the reason for track 4 being gone on the SYNC head...
that little bugger must have broken off when I had the assembly out. I soldered it back on, and now all tracks are working on the SYNC/record head! Records and plays on all tracks. But still no track 1 on the playback head.
and yea, still no track 1 on the repro head. There´s a bit of a blemish on the upper right corner of it, I don´t know whether it´s a scratch or some gunk, but I couldn´t get it off. It seems like it´s not in the tape path though. Would you say this is clean enough?
I´ve read that the solder joints can be bad on these machines, and that resoldering the connections on the motherboard could be a solution to a problem like this. I´m ok with a soldering iron, so I could do this - but is the motherboard the PCB that the amp cards are plugged into, or the big PCB board that´s positioned vertically on the back of the machine?
Well just make sure you look at the heads under good light and with magnification if necessary. Put up a pic of the heads if you can.
Somebody else more familiar with the 30 series will need to chime in, but I know other period models of Tascam machines had muting relays mounted external to the amp cards, like on the motherboard. If those go bad that can cause signal issues, but that wouldn’t be specific to individual tracks on the heads, the relays cut the signal to the outputs when powering up to avoid the thump at the outputs.
Sorry, it was a bit unclear - I meant no signal on track 1 on the playback/repro head specifically. And yes, I´m using a recording with all 4 tracks recorded. I cleaned the heads as well as I could with isopropyl:When you say no repro on 1, does that mean no signal from the sync or repro heads? And you are using a known hood recording with signal on all 4 tracks?
