LazerBeakShiek
Tell Tony, Eddie an the Cruises IS here
Appegiating guitar turned down, filtered back to 80-4k. Refrains distorted guitars are too loud now..right?
First thing tommorrow.high pass arp guitar at 150, low pass at 10khz, scoop a lot out at 1khz, boost some 8khz, if you brought up too much harsh then cut some 2-5khz, this will make your arp guitar (not the focus) give nice shimmery high end, turn it into a supporting instrument while clearing space in mids and clearing up the low end of your mix a bit.
After I get a balance, I want to try the sub group thing with the guitars on a fader.Get a balance where your guitars sound the same in volume with the faders, use EQ to create further seperation, and to balance brightness. To me the arp stole ALL of my attention, it's just too loud and big.
My voice is ....Im a garbage vocalist. I can force it to make sound. As you have heard. Burried it is then. i will put it back in.If you like your vocal buried,
There is a lot more to it than most think. You could be right, but this helps plenty. Many thanks..
I don't think it's possible to walk you through this,
Dyslexia is a terrible disease. I read is as you having a Meteora LP...as in vinyl record.Linkin Park? LP.
You've got reverb on your master track? WHY, for ferfuckssake?
There are many changes. Tightness and in the bass. Scared for life, was -15 LUFs and -5 Mastered. It was really brought to life. There is the level change, done by what could be the compressor. Interesting. Thanks. Tell me more about what I hear.OK, I uploaded three full songs
its pumping badly
Dude, they are all comically bad.That track needs some work
