Dear all
I need help regarding vocals and EQ
1. My vocals lack warmth.It's an ongoing problem. I use Shure 58beta , UR22 and Softube plugins, Waves and little Soundtoys. Usually i pan vocals left/ right , de ess them, eq, compress , duplicate, compress by different comp. add ad-libs. On sends i add bit of reverb around -10. Effect is most of the time same- very flat sounding vocals.
2. Iam bit confused with EQ . Why standard preset in cubase for man's vocals have 0.0db . Should frequencies under 100hz be roll of by - db?
3. To avoid clipping i keep vocals,instrumentals, and master buss -db . Hence after applying limiter on master buss is it a common practice to bring up levels ( lets say from -3.6db into -0.3 master buss only) or keep it the way it is.
Cheers
Cheers
