When i listen back i always hear the things that could be done or mixed better. Even when 'the crowd' say's it's wonderfull.
When i'm just finished i like it (otherwise wouldn't be finished). When i listen a lot later this statement of 'could be better' then becomes.
But the strange thing is that if i start mixing again the result of that ain't that much different than the first release. So in the end, also because others like it, i say 'didn't do it that worst'.
But i thinkt that's cause i'm in a new learning curver of recording, nowaday's with DAW and aspecially much more plugins to learn.
And i think i should work together with other musicians more. Recording and mixing is going quite well, but my main problem is that i shouldn't do everything myself like i do now, like singing for instance. When i record and edit, and play but let others sing the result many times is much better.
And on that the same problem Delmont has. 'The crowd' still could grow.
