Farview
Thanks everyone.
So you adjust the volume of each song individually by using gain knobs? And then after that the limiter is on each track or is it on your master bus?
Do you guys take things like crest factor into consideration and try to make it the same on each mix before going to the master stage? I'm wondering if my mixed versions (-20db rms/-6 peak) have too large a crest ratio.
I use the clip gain to adjust the individual volume and the limiter is on the meter bus.
