Atkron205
Member
I have not done any collaborating with other people, what I mean is having someone send me tracks for part of a song or vice versa. from what I have read you can export or import files using the pool. is this the best way to say, if I have drum tracks I want to send to someone else, do you just convert them into wav files from the pool? as long as the file format is the same, if someone sends me a track (file) can I import it into the pool and go from there? not sure of the best route to take. as long as we keep the file format the same, it should not matter what DAW is used, correct? should the files just be raw tracks without any processing? I assume one person would have to do the final mixdown as far as effects, comps etc. is this correct? Thanks
