H
hansmoleman
Hi,
Been looking round to try and work this one out, and there seems to be no definite answer other than reduce latency with faster hardware from the start. However...
I'm running a Lexicon Alpha into my laptop (i3, 8GB RAM) which is running Cubase (I've just switched from Audacity). Audacity used a latency correction that re positioned the track after the recording.
In Cubase, under device management it tells me latency is 36.077ms. Because I use hardware monitoring through the Lexicon which is no latency (or very low) does this not mean I can just correct latency is Cubase by exactly 36.077ms for every track I do? Why isn't this the standard answer, it seems too simple for latency to be such a huge issue!
What have I missed? (and how would I do this in Cubase 5 LE?)
Thanks!
Thanks!
