ProfessorShred
DP24 Freezes/Locks up no matter what sd card you use in 24bit depth mode
Been using Roland Vstudio 700 i/o and control surface for a few years now,decided after reading about the new DP24 it would be a great tool/sketchpad for recording new ideas quickly,and I would be able to transfer the wavefiles to the daw if I desire,so I purchased one.Recordings in 16 bit mode sd card works fine,its when you switch to 24bit depth that all hell breaks loose,i tossed the crappy sd card that came with it and purchased a 16gb sandisk Ultra 10 class SD card hoping to solve the freezing/lock up of the machine,when working in 24 bit mode I was only able to record 2 or 3 tracks before the machine just locks up,and there is no response even pushing and holding the power button … you have to unplug the power supply in order to reboot the dp24
at this point you will either have totally lost your track data,or the sd card is unusable until you put the sd card into a computer and reformat it,then you can use it again in the dp24.I read a review from someone on amazon.com who purchased 2 units and had similar issues,he apparently talked to someone at Tascam,they are aware of the problem with the dp24,but don't seem to be too concerned to get a firmware update/fix out very quickly,it bothers me a great deal that they rushed this product to the market with such a severe problem left unchecked and now don't seem to care about releasing a timely fix.
Except for slight background hiss after the dp24 boots,and the already mentioned lock up dilemma,I think very highly of the product,its a true bargain for what you can get one for online,just hope they solve the problem soon!
*UPDATE*
Been experimenting and the dp24 has been working quite nicely with 24bit/48khz,it is only crashing with 24bit/44.1khz setting
*UPDATE*
