If you want to know what a figure 8 pattern looks like, it's two perfect circles, one on top of the other. (The distance of the line from the center of the graph, in a particular direction, represents how strongly the mic picks up a sound coming from that direction).
If you're so inclined, you might want to think about what makes the pattern shaped the way it is. A ribbon mic is a "velocity" mic: it picks up a signal when the ribbon moves in response to being pushed by air. If you push the ribbon straight-on from either side, the whole push gets transferred to the ribbon. If you push the ribbon from the edge, it doesn't move at all. The amount of the push that gets transferred is the cosin of the angle off of straight ahead: make a polar plot of the cosin function, and you get a figure 8 (okay, actually you have to chart the absolute value, but that's a technical nicety).
