I'm sure that we can come up with some mechanism to do that. if Fostex USA remains resistant. However, I'm beginning to think that a grassroots campaign of D-series owners calling up Fostex USA (800-936-7839) and outright demanding that they provide this update to their current customers would be useful as well. They really do need to support us now and into the future, rather than forcing us to scurry off to the international distributors for the updates to keep our machines going!
I now have all the release notes for the chain of releases leading up to V2.02. The added features (V2.02 vs V1.08) are as follows:
1. Removal of the punch-out mute: the machine now switches instantly from record-monitor to playback-monitor with no 2-second mute. Big win.
2. The total track count has been increased from 24 to 56: so a D824 will have 8 physical and 48 virtual tracks, and a D1624 will have 16 physical and 40 virtual tracks. However, data recorded in 56-track mode under V2.x will not be readable by a V1.x machine without doing a destructive conversion: more on this next.
3. Conversion of V1.x 24-track data to V2.x 56-track data via an entry in the Setup menu, allowing your old disks to be safely updated to the new format *without* having to delete everything and start from scratch. You can apparently also convert from 56-track back to 24-track as well, allowing v1.x and v2.x machines to share disks (although the data from the new virtual tracks 25-56 and the Multiple Undo data will be lost, if you go backwards). Wonder what Fostex USA is so damned worried about?
4. Addition of a Chain Play function, which allows you to set up a list of programs to play in sequence.
5. Mark Stop mode, to force the machine to automatically stop at every memory locate point if desired.
6. The foot switch can be used to control either play/stop or the standard punch in/out functionality by a screen in the Setup menu.
7. Auto EE mode added: puts the machine into input monitor mode automatically when stopped, if desired. I'll use this a lot, to use the internal D/As to monitor 16 tracks from my DAW. This will be much easier and less risky than having to use record-pause! A big win, and completely unexpected...
8. Addition of the 88.2kHz sampling frequency as an option.
9. Allowing each program on a disk to have a different sampling frequency if desired (instead of being locked in to one sampling rate when the disk is initially formatted). Another unexpected big win.
10. Support for Maxtor drives (write verify speed incompatibility, write verify has to be turned off).
11. Support for disks up to 137Gb.
12. Ability to display up to 100Gb remaining.
And a handful of bugfixes. All in all, it really does make the damned thing into a MkII unit, just as NoKi pointed out- you just don't get the sexy black faceplate and the new drive carrier.
I still haven't installed it on my machine yet: I was backing up all my old data, thinking I'd have to reformat from scratch. If time permits I'll do that tonight. And time probably will permit, given that I have over 4 feet of snow on the ground...
