USB Mixer or other way of recording multiple mics into multiple tracks?
  • Thread starter Thread starter hc803
H
hc803
Hello, newbie to forum and digital recording.
I'd like to record some demo/ideas that would include an acoustic drum kit, guitar, bass, and vocals in my basement.
Assuming I already have microphones (SM57/58, drum mics, condenser overheads) and a competent computer with DAW software, what's my next step?
I would go the 2-input interface route but I'm anticipating at least 3 mics on the drum kit alone, and may be accompanied by other musicians in a "live recording" setting, so multiple inputs is a necessity.
The Alesis Multimix 16 2.0 seems to be what I may need (?) but am I missing out on another possibility that would yield similar results?
Sorry if the request is a repeat, I've lurked the forum for two weeks before posting this.
Thanks!
Just get an interface with enough inputs like the Tascam US1800. The DAW will be your mixer.
J
The Alesis will MIX your 16 input channels (or 8 mic channels, whatever you're using) to a stereo USB signal - it's a mixer, that's what it does. If you want to record each mic/instrument onto a separate track in your DAW you want an audio interface.
Read the "Mixers and Home Recording" sticky up top... that's why it's there.:thumbs up:
I had looked at the Tascam US1800 too, but I guess I thought about it backwards.
The reviews of the Tascam seem to be all over the board. Yay or nay?
You won't find a better bargain interface wiht 8 mic preamps than the US1800, which is being replaced in the Tascam lineup shortly.
I have an Alesis Multimix 16 USB 2.0 - it does send 16 tracks to your DAW via USB. The NEW model is only stereo though so if you're buying be careful. Also the 2.0 is no longer supported and does not have drivers for Windows 8. It MAY work on W8 but I haven't tried it as my laptop is W7.
Looks like the US-1800 only does 4 tracks out. I anticipate needing/wanting more than that. So am I back to the Alesis? Or wait for that cheap Behringer to come out?
The US1800 does 16 tracks in, that will more than adequately fill your needs to record drums, guitar, bass, etc. All 16 tracks are transferred to your DAW via the USB connection. You'll use the 4 analog outputs for things like sending a stereo signal to your monitors, or connecting outboard gear.
You can always try mixing the multiple mics for the drums down to stereo before they go into the interface. It's good practice for mixing, and it gives you an idea of how the mics work together. I've got our kit miked up with two overheads and the usual complement on snare, kick, etc. and I send these to a sidecar mixer whose stereo feed goes to the main mixer. That signal goes to the interface. I have to do this because I only have ten in and ten out at the practice space. Since these sessions are for song-idea or writing reasons only, it's not crucial that they be "perfect." However, I've learned a thing or two about mic placement and mixing in the process. Great fun.
What do you need more than 4 outputs for? Two outs feed the main monitors. The second pair could feed two "grotboxes" or maybe you want to setup an FX loop in the software (trick baby!) . The only other reason I can think of is 5.1 or 7.1 monitoring? (ambitious AND tricky baby!)
Speak to us of your need friend.
