Outlaws
So I just yanked the chasis out of my ProJunior. Its time to make a head so I don't keep thinking I just pissed off a rattlesnake.
Problem:
The chasis was designed for the controls on top and the tubes facing down.
(see pictures below)
Now I am really not interested in having a head with the controls on top and the tubes staying where they are. The thingwould be at least 10" tall. Thats a big head IMO considering the chasis is only 13.5" accross the front.
So I am thinking that if I make it around what is already there, and I use a thin sheet of metal for the back plate rather than what thick bottom would need, I can make it 9" deep instead of needing 10". And depth won't look as dumb as being tall.
Now the question:
Is there any problem with having the tubes horizontal?
I can't seem to see why they would need to be in a verticle manner for any reason if upsidedown and rightsideup don't matter.
I also realize that the tubes would be close to the bottom, so I would probably mount the chasis on a 1" piece of wood first.
Any thoughts on this?
Also any suggestions for a better way to make this head container?
Eventually I would make a matching cab for a 12".
Problem:
Now the question:
.In fact,the only issue with shorting "elements" appears in a direcly-heated triode where,if wrongly positioned,the hot filament bends and shorts with the grid.
