antichef
pornk rock
Just came here to bitch - I got a Vox Tonelab SE when they first came out. It's a pretty cool thing, and my son and I have used it for some gigs. - Yes, I prefer real amps - but these are a lot easier to haul around than an amp and pedals, and when we were playing mere supporting roles, backing up other instrumentalists, it was fine. It sounded kind of clippy at first, but I used a lower power tube in the tube socket thing, and it cleaned up well.
Anyway, it uses a funky power supply - 9V AC (not so weird I guess) and a strange multi-pin connector (the weird part). Recently the connector broke off in the unit, leaving the stumpy bare wire by itself. No problem, I thought, I'll order another one. Found a local Vox supplier, waited... and now the word is that Vox doesn't make them anymore and I'm screwed.
So the unit is permanently bricked - trash, basically. I guess I'll try and fix the cable myself, but jeez - they marketed this as something you could rely on. The unit itself seems sturdy enough, and has always worked fine.
What can be learned? I guess when you're buying something, look for crappy little proprietary breaky stuff, and beware.
