A
Alchemist3k
I wasn't aware of this before but I read in this month's "Computer Music" that it is a good idea to record at as high a resolution as possible, preferably 24bit depth at 96khz, then when you create your final mixdown .wav file you can convert to 16bit/44.1khz for writing to CD yet still retain a higher quality than if you had recorded at 44.1 16bit in the first place.
Aparently this process is called dithering and Cubase VST 5 has an algorithm by Apogee which does this very well indeed.
It's a technical thing I know but I thought some of you may be interested (esp as the higher the recording settings the less latency too so you get two advantages for the price of one!).
