JDOD
therecordingrebels.com
Just moved into the new house, it's still a wreck but I can have the front living room for the TV, computer, guitars and amps.
its a pretty old house with a fireplace on one wall and chimney breast above it. Computer/tv area will be on a shelf to the left of this. Was going to put the amp on a wooden shelf about 30cm off the floor to the right of this (handy space under it for leads/pedal board).
Should I mount the amp on something like neoprene to deaden it or will it be ok sitting straight on the wood shelf?
The room currently has carpet but has really nice wood block parquet flooring underneath. You think ill get to much room in the noise if I got back to the parquet? Could this be compensated for with a thick rug?
There'll also be two small sofas in the room and the guitars will be mounted on the wall adjacent to the amp.
