Yeah, basically you need to know the the impeadance or ohm rating of each speaker inside the cab is.
Usually the "Standard" if you will for a 4x12 mono/stereo jack plate set up is: 4 & 16 ohms in Mono, and 8 ohms in Stereo (8 ohms per input jack)
So if you just get one of these jack plates like from Marshall or Carvin, it would make this job real easy and professional looking.......not to mention giving you a couple of more hook up options.
Here a link to the one from Carvin:
http://www.carvin.com/products/single.php?ItemNumber=CGC412&CID=GSPK
It looks like they changed it a bit, but it would still work..
The Marshall one is model#S-H800 and list for 19.99
http://www.tubesandmore.com/new/scr...elevclients/cemirror/ELEVATOR.FXP?item=S-H800
And here's some usefull info on guitar cab wiring: C:\Documents and Settings\Bryan Cantu\My Documents\Music Gear\Guitars and amps\4X12 Wiring instructions.htm
Rick
