M
matthew_a
Hello gents,
I'm looking to upgrade my recording hard drive, I've done my share of research and am looking at something 7200rpm, external, portable, and with small capacity. I'm pretty set on picking up a Glyph portagig800 160gb, although I'm also looking into LaCie, but I'm just looking for last minute wisdom on this purchase. I'm running XP on a Dell Latitude D830, dualcore 2.0ghz, (soon to be upgraded to) 2x2gb of RAM.
My super quick question involves the portagig. The only FW connection is 800 (9-pin) and my only connection on the laptop is 400 (6-pin). Also, that connection comes via a PC card. I've heard that using a 9 to 6 pin FW cable from the harddrive (9pin) to the PC (6pin) will work fine, but I'm a little queasy about that. My only other option with the portagig is USB, and supposedly to use the bus power you have to use the Y-configuration cable which I'd rather avoid (and obviously FW is just faster anyway).
Also, if anyone has any general thoughts on brands like Glyph...they're tailored to recording, but is it just a gimmick? is it worth the little bit of extra cash? Thanks
Matthew
Matthew
