Recording Capabilites of V Amps
  • Thread starter Thread starter pearljammin'
P
pearljammin'
What exactly do the BASS V-AMPs have in the way of recording capabilites? I know it has midi outputs, so would I be able to record my band playing when the V-Amp is plugged into a PC?
Thanks for any help
No.
The MIDI ports are usable to control the parameters of the VAmp. MIDI data is not audio data.
You need to read up on what MIDI is. Don't feel bad, a lot of people make the assumption you are making about MIDI before they know anything about it.
Thanks, so what would you recomdend for direct guitar/bass recording straight onto a laptop?
You should definitely be able to record using the V-Amp direct into your audio interface...
John -
byzantine is reflected in my pond
Will the Bass guitar go straight into the computer without anything but a balanced line into the studio hardware.In other words do I need to give it any more power
You have to bring the signal up to line level with some sort of preamp be it a mixer, a v-Amp or some other accessory.
